Im just getting the parts together for my Indy R build, i've just bought an ST150 engine but I'm looking for the other donor parts
needed.
Things I'm after:
Sierra rear bearing carriers for bolt on shafts
Sierra steering column and link joint
Mike
[Edited on 15/10/14 by Valentinik]
[Edited on 16/10/14 by Valentinik]
I have the bearing carriers for push in shafts. not a clue what they're worth though?
to help you widen your search a bit - mk3 Granada's and Scorpio's use the same bolt-on rear hubs as the sierra
and the Granada column is very similar to the sierra one too
but unfortunately the front hubs are a different geometry
where abouts are you..
I am sure I have a column or 3 lying around..
nightmare to post thou!
pm sent.
Got everything and other stuff !
I'm in Tamworth so quite a way.
Pm sent
Mike
