VORTX WIRING DIAGRAM
Krismc - 3/6/07 at 06:22 PM
I got a wire list with my wiring harness but i never recieved the diagram, its just i keep losing my ECU feed and would like to trace wire back to the supspected faulty relay.
any help is appriciated!
chockymonster - 4/6/07 at 08:33 PM
Diagram?
There was a diagram?
RichieC - 4/6/07 at 08:56 PM
Yeh, same here. Ive not heard of anyone having a diagram.
I assume youre talking about a perm +ve to your ECU?
Have you confirmed there is definately not perm 12v on the Green from the fuse box?
The relays are identical so to confirm a suspect one is easy enough.
neilj37 - 5/6/07 at 06:50 AM
Never got a diagram with mine either, just the booklet which identifies all the wiring
[Edited on 5/6/07 by neilj37]
Krismc - 8/6/07 at 04:25 PM
well sometimes when cranking i loose my ECu feed, and therefore cant start the car, never had much time to look into it yet, but im sure there is a wiring diagram out there!
