ESC ignition Module
The Baron - 25/11/10 at 04:28 PM
I am having a senior moment, on the ESC ignition module, is the plastic tube outlet, for vacuum advance from the carb?
B
Davedew - 25/11/10 at 04:53 PM
If you are talking about the ESC in a sierra, then you should have a tube that connects to it from the inlet manifold. It is a built in MAP sensor for sensing engine load & adjusting the advance & retard of the timing.
big_wasa - 25/11/10 at 06:05 PM
yep.
The Baron - 26/11/10 at 08:25 AM
ta
