Caliper Carriers
scootz - 30/1/10 at 01:15 PM
I bought a set of these from Rally Design... I knew they wouldn't do the job as they are for a Fiesta fitment, but I wanted a nosey anyway.
Does anyone know if anyone does a Sierra version (I've looked but can't find any).
Finally... what material are these - (goldy-bronze colour).
Ta!
mangogrooveworkshop - 30/1/10 at 01:22 PM
Steel for the material with a cheap galv coating
Front Brakes:
Ford Sierra discs and calipers. Depending on the Sierra chosen, discs will be 240mm dia. solid, 240mm dia. vented (most common) or 260mm dia. vented
As a cost effective upgrade for Rushes fitted with 16" diameter wheels and above, DAX can supply adapter plates which relocate the standard Sierra calipers (240mm dia. vented disc type) allowing them to be used with the much larger, 278mm dia, Cosworth 4 x 4 front discs
scootz - 30/1/10 at 01:28 PM
Cheers Mango!
It's to change the rear drum set-up to discs... does that influence things?
Alan B - 30/1/10 at 01:43 PM
Definitely steel, but not galvanized. Galvanizing is hot dipping and is greyer with a cystal pattern...that is plating.
MikeCapon - 30/1/10 at 01:57 PM
It's zinc plate with a yellow chromate conversion or chrome passivation. It's one of the best ways of protecting steel against corrosion.
Galvanising is simply dipping the item in molten zinc. Zinc plating is an electrolitic process.
hicost blade - 30/1/10 at 02:16 PM
MNR them £30...
http://www.mnrltd.co.uk/index2.html
Is what your looking for I think
[Edited on 30/1/10 by hicost blade]
scootz - 30/1/10 at 02:31 PM
Thanks Hicost... just the very fellows!
[Edited on 30/1/10 by scootz]
mookaloid - 30/1/10 at 04:37 PM
I got some from Matt at http://www.casarva.co.uk/
they were very reasonably priced if I recall
bracket2
bracket2
scootz - 30/1/10 at 06:05 PM
Cheers Mark... quite like that they are 'open' - easier fit!
gavin174 - 30/1/10 at 06:25 PM
I have a set like the MNR ones £20 + p&p
U2U if interested....
Angel Acevedo - 31/1/10 at 05:01 AM
Please check with manufacturer as it could be cadmium plating which compounds are carcinogenic.
I stand to be corrected, but better safe than sorry.
AA
ghostrain - 31/1/10 at 04:47 PM
The brackets you picture are to fit Fiesta Mk1 front calipers onto the RWD english axle...it is a cheap mod mainly used in oval racing. The brackets are mild steel with a gold colour zinc passivate finish,the gold passivate is more scratch and impact resistant than normal zinc plating.
From later posts it looks like you are trying to fit Sierra rear calipers(with integral handbrake) to a Sierra drum brake donor wishbones or a design based upon that setup...have you considered Rally Design's BK64 kit which uses the Golf Hydra-Mech caliper,240x10 solid discs and ally bolt on mount brackets,it is cheap only £219.45 + vat for the kit but will only fit inside 14" wheels.
Also I know that Rally Design is making a batch of Sierra rear calipers but won't be available for 4 months.
Hope that helps
