Hi All
We're on the verge of leaving Sky as they have been unable to resolve a problem (which they know about but won't acknowledge!). Because of
the problems, they have credited our account but I want to leave and access this credit (it's over £300!)
Does anybody know if this is possible or has anybody done it? I know I can ask Sky but I wanted to find out if anybody has done it before they tell
me no!
The problem, by the way, is a conflict between Sky HD boxes and certain makes of TV when using HDMI - this results in the Sky box giving all sorts of
errors like failed recording etc. The only solution is to use Scart which kind of defeats the object of having HD!
We're thinking of BT Vision as a replacement.
Ta in advance
Wyn
i used to work in their customer services, as you'll know, monthly payments are made in advance, (so if you made a payment today, then that
covers you for viewing from today til 13th july, if you cancelled next week, you've be due credit back from the day you cancelled til, the 13th
july and thats refunded back into the DD account, thats just a bit of background though)
so, yes, if you cancelled, you'd be due that money back, and it will be refunded back to the account your payments come from, or card if you pay
by card. can take a few weeks to go through, but you will get the money, as the refunding of credit is standard practice, and the credit is not just a
good will thing, but credit for payments you've made for service you've not had
[Edited on 13/6/12 by blakep82]
Thanks blake!! They've credited our account for eight months worth of viewing and we'll be leaving in a month I think so I want to make sure
I get it before leaving!
The funny thing is they still want to send an engineer even though the problem is in the software! And even funnier is the engineer who usually calls
lives not far from me and does a bit of rallying so we spend most of the time in my garage!
if i remember rightly, they won't really refund your bank account if the sky account is still active. I mean they CAN, they just prefer not to.
they'd rather that if you stayed with then, you get several months that you've already payed for.
if you want the money back before cancelling, phone up, lay it on thick, say you really need the money back, you've got other bills to pay that
you could really do with the money back for.
if they won't, then you WILL get the money back after cancelling, don't worry about that. its your money!
if they want to send an engineer, they'll insist on doing it to keep you as a customer, but keep at them saying you want to cancel, they
can't force you to stay, although depending how long you've had the HD box, you might be stuck in contract, if you are in contract, and
they're being an arse, they might charge you for the rest of the contract time, which is charged at the minimum rate (ie 1 basic package, i think
thats about £20 a month). a replacement box might work though. I think it was only some boxes that had the issue.
if you haven't already, you could try a software download. the box downloads its OS through the satelite system, something to do with switching
off at the wall, pressing the back up button on the box, NOT the remote, and keep holding it down while you turn it on the box back on, and keep
holding it till all the lights come on the box, and a message appears on screen. then leave it for about 20 minutes til the message goes away, then
press the sky button on the remote
They've already told me I can leave after giving 30 days notice (they're probably fed up with me by now!).
We replaced the box a few months ago and have the latest software downloaded. It is a specific software fault with Technika, Baird and maybe a few
other makes of TV - I have a copy of their internal technical memo but haven't needed to play that joker yet! I could change the TV but
that's not the point!
The Thomson sky HD box has component output as well as HDMI. So if the TV has component that could be an alternative to still output HD although it
would need to be an upgraded psu Thomson box as the standard ones came with dodgy capacitors.
They will also not receive Anytime+ or the new EPG update that's being rolled out soon.
You will not get a Thomson box as we dont do them any more sky make there own boxes now as they took over amstrad in order to control the quality of the new boxes have any one who as called to your house changed the cable or have you got an alarm on your house with pri censer in the room with the sky box i cany see why your tv will stop it recording i have worked for sky for 5 years and not come across any tv that has this problem mate
