Hi All got a 51 plate corsa and the washers have packed in
pull the thingy and there is no power going to the pump. wipers move ok but no water comes out!!
pump ok as tested with a direct feed and fuse seems ok too!!!
Help which relay as it does not tell you in the book!!!!
cheers
Brian
No previous experience of this model etc but are you sure its relayed? Most squirts work by giving a direct feed via the stalks.
Sorry I can't be more specific and i'm sure someone with a haynes will be along at some point
G
yeh would have thought there'd be no relay aswell....could be wrong though...Oli.
