Just noticed my engine is only running on 3 cylinders, took carb off and found one of the needle valves to be missing. Its the one just downstream
from the fuel chamber just before the manifold connection (i don't know what you call it but i think you get the picture)
When i put my finger over the hole the engine fires fine.
Anyway, does anybody know where i can get a replacement needle valve for it. Cant find it on the net.
Cheers...Andy
Originally posted by spud69
Just noticed my engine is only running on 3 cylinders, took carb off and found one of the needle valves to be missing. Its the one just downstream from the fuel chamber just before the manifold connection (i don't know what you call it but i think you get the picture)
Cheers...Andy
