S2000 built engine
Gdb2013 - 24/3/13 at 11:22 AM
Hi there, I m new to this site so I thought I d give a brief post on what I hoping to do .being new I m probably posting in the wrong place but I m sure that I will be directed by you more experienced guys.Anyway I ve had a number of honda s2000 over the last 3 years and am now looking to give a go at a full built westfield kit.I have invested in a fully built Honda s2000 engine producing over 350 whp and is totally N/A .Now I m looking for help in where s best to get parts and what's best for the build .I m no expert in mechanics but I can do most simple things .I hope you guy s can point me in the right directing as I m on a budget so any help would be greatly received .thanks
froggy - 24/3/13 at 11:33 AM
im a bit confused ? is your built engine naturally asp? they make 200whp in standard form so an extra 150whp is an incredible achievement without forced induction
wylliezx9r - 24/3/13 at 11:46 AM
I agree getting that sort of power out of an n/a f20c would require serious investment so the 13k kit price for a Westfield megaS2000 should be a drop in the ocean.
If your buying the westfield full kit it should be a doddle to build with full factory support.
Welcome by the way.
Gdb2013 - 24/3/13 at 12:20 PM
Sorry posted the reply as a new post my bad.
daniel mason - 24/3/13 at 01:05 PM
id imagine a 350rwhp engine is way above the budget of most peoples complete build!
lets see some pics of it!
ReMan - 24/3/13 at 02:12 PM
copy and past into this thread, it confused tfo me!
mark chandler - 24/3/13 at 02:21 PM
First thing would be to source a crashed s2000, this will donate gearbox and axle, steering column etc, then sell the rest on to recover some funds.
You then modify the frame around this lot, you will probably want to use cortina uprights and sierra rear hubs or Westfield equivalents so you can run nice 13" wheels and have access to decent brakes at sensible prices.
Escort quick rack, just mate to the s2000 column by modifying the tube between the UJ,s to suit.
Pedals, get a nice floor mounted set with balance bar.
Jobs a goodun
Gdb2013 - 24/3/13 at 03:16 PM
Hi thanks for the info, I have Honda s2000 steering colum,ecu,loom,transponder,also have a re built s2000 gearbox ,is there anything else I can use from the Honda car as I have a load of parts left over from my supercharged Honda build I sold on.I put the car back to standard form when I sold it and kept all the performance parts.so is it best to buy a frame direct from westfield and take it from there?
perksy - 24/3/13 at 03:42 PM
Welcome
Believe Westfield are now selling an Honda S2000 engined variant, So it might be worth a chat with the factory about the chassis and kit spec' etc.
The standard SEIW (Widebody) chassis will take the S2000 engine with some modification to engine mountings etc.
Have heard one or two owners say that the ratios on the standard S2000 gearbox are ok but could be better when used in a Westfield.
I had a good look at one that was going to Germany and had to have all the standard induction set-up and it was pretty cosy under the bonnet, although it did also have a dry sump install.
Gdb2013 - 24/3/13 at 03:54 PM
Hi , I read somewhere that as the gearbox n the Honda was low that there was no need for a dry sump system as they are the same level.i ve had all the brochures on the kits from westfield and am going to give them a ring next week see what options they have.i suppose the AP braking kit would be in order or are there any other options that you would recommend.Would I still be able to run the AEM EMS on the westfield or is there other options available .
perksy - 24/3/13 at 07:10 PM
Speak to Westfield and try and talk to Mark Walker if you can as he will be able to answer all the technical questions or speak to Russell who's also very good.
I notice you want to use a high power S2000 engine and not a normal version, so make sure they are aware of that.
They *may* recommend some bracing on the Diff carrier area of the chassis.
Have a good look at what is on offer with the kit and then budget it accordingly, Don't forget that you don't have to buy everything from Westfield and some parts can be found cheaper from other suppliers.
They may do a discount for a 'package' of components.
Get yourself a build manual in advance so you'll know whats involved.
Good luck with the build
Gdb2013 - 25/3/13 at 08:10 PM
Thanks for the info , I m phoning
Westfield tomorrow for further information on there kits
perksy - 25/3/13 at 08:56 PM
If you have a look on the Westfield club website there is a lad on there putting together an S2000 engined Westy
http://forum.wscc.co.uk/forum/index.php/topic/92857-finally-started-my-s2000-build/
Hope that Helps
SeanStone - 25/3/13 at 09:18 PM
What's it had done to make that power at the wheels N/A?
Gdb2013 - 25/3/13 at 10:06 PM
I have posted the spec towards the start of tbis thread, but if you go to urgedesign.com ive had all that work done to my engine which is his gt motor .
