front wings
whitstella - 17/8/11 at 05:16 PM
hi
thinking about fitting my front cycle wings so just a couple of questions.
1. whats the best way of fixing them to the brackets?????
2. which is the corret position????? how far back over the wheel if you know what i mean.
cheers steve
stevegough - 17/8/11 at 05:29 PM
Question 1: fit them with gunge - I used 'Tigerseal'.
Question 2: see the drawing in the IVA manual - it is self - explanatory.
martynrich67 - 17/8/11 at 09:34 PM
Let me know if they wobble about a lot, coz mine do.
Myke 2463 - 17/8/11 at 10:15 PM
The manual shows the wing just forward of the front of the rim, i thought that someone posted that the wing must be at least forward of the tyre, right / wrong ?
stevegough - 18/8/11 at 08:25 AM
er, wrong. The front of the wing must be just in front of the rim (as stated above) and the back edge needs to come just below the centreline of the wheel.
And to answer Martin who was rich in'67's question; no, mine don't wobble at all - even at 120 mph. Let me see if I can find a piccy of the gungy stuff fitment...yes - not very clear, because after fitting the stays, I also used some of Car Builder Solution's um, solution called 'Wunderseal' on them.
Also - to help illustrate the wing fixing position for Whitstella and Myke 2463 - here's a profile pic of mine...
sprouts-car - 18/8/11 at 08:39 AM
So is this right?
stevegough - 18/8/11 at 08:45 AM
Originally posted by sprouts-car
So is this right?
Perfect illustration.
sprouts-car - 18/8/11 at 08:58 AM
So is this right?
Is there any logical reason for that amount of coverage?
Ie the back is to stop stones being thrown up (not that I think it would stop that)
eddie99 - 18/8/11 at 10:29 AM
As above on position and i also used some tiger seal type stuff and was perfect, survived 110mph at north weald with no noticeable movement at all.
Pezza - 18/8/11 at 04:37 PM
From the IVA manual
sprouts-car - 19/8/11 at 04:09 PM
So my diagram is wrong (I was just trying to clarify what had previously been said in the thread.
I assume the IVA answer is the correct one?
martynrich67 - 21/8/11 at 04:31 PM
Mine snapped again today - same bracket different place.
I think it needs a new bit of flat bar - maybe it's fatigued.
Ah well, caliper and wishbone off again tomorrow to allow repairs!
StevenB - 29/8/11 at 10:13 PM
There was a thread ages ago saying the forward measurement
was a vertical line off the wheel rim but that would change
depending on the wheel size whereas the 30deg forward will
always be in the same position.
S
handyandy - 29/8/11 at 11:50 PM
I was having a similar discussion after posting photos of my finished car when someone commented that my cycle wings wouldn,t pass the IVA requirements, so I copied all the measurements as stated in the IVA manual onto a perspex sheet & placed it against my wheels to check my wings.
Below is a pic of how it translates & you can see that my wings will pass the IVA test.
Hope this pic helps, it also depends on the individual shape/style of the cycle wing in relation to what position of the wing will pass/fail
cheers
andy
[Edited on 29/8/11 by handyandy]
