ZX9 speedo
TheHighlander123 - 16/2/17 at 08:24 PM
Hi lads
The kit car garage are near finished my ZX9 B conversion.
They have told me the ZX9 cluster is working but the speedo is not.
Neutral light and all other lights are working aswell as the rev counter.
Is there anyway to get my speedo working?
wylliezx9r - 16/2/17 at 10:15 PM
Originally posted by TheHighlander123
Hi lads
Is it wired up to the correct speed sensor ? If so it should pick up of a bolt head on the prop. That's how I did mine. But you'll also need a speeding healer for the correct reading.
TheHighlander123 - 17/2/17 at 07:08 AM
Could you send me more details to forward on about this.
What did you do for a speedo cable?
wylliezx9r - 17/2/17 at 10:09 AM
When you say cable do you mean electrical cable ? If so I used the one that came off the bike. Just bare in mind my install was a C1.
Edit: I've done a bit of investigating and it looks like the B uses a mechanical drive for the speedo. In that case I would say your better off going with an aftermarket speedo.
[Edited on 17/2/17 by wylliezx9r]
