r1 carbs-which hole do i block?
adrian - 18/6/07 at 08:56 PM
just been reading through a previous threadhttp://www.locostbuilders.co.uk/viewthread.php?tid=67564
[Edited on 18/6/07 by adrian]
[Edited on 18/6/07 by adrian] Rescued attachment r1carbholes.jpg
skydivepaul - 18/6/07 at 08:59 PM
hole no 1
smart51 - 18/6/07 at 09:23 PM
Yep, hole number 1.
oadamo - 18/6/07 at 09:28 PM
just out of interest why do you have to block one of the holes off
adam
[Edited on 18/6/07 by oadamo]
adrian - 18/6/07 at 09:59 PM
thanks guys!
oadamo- i think its to improve the response of the slider?
can anyone provide more info?
smart51 - 19/6/07 at 07:11 AM
the jet that you block feeds air into the needle jet. What I think it does is lean the fuel off at high revs / full throttle whilst keeping the fuel rate up at mid revs. This is to match the restriction in airflow caused by the exhaust / airbox at high flow rates. When you fit freer flowing parts to your engine, you want a more linear fuel flow so you block up the hole.
adrian - 19/6/07 at 09:18 PM
would this still be a good idea in a bike engined mini?
as the air flow isnt as good as a 7 type vehicle
z cars recommend 128 main jets perhaps because lack of air flow?
should i think about some ram air?
smart51 - 20/6/07 at 07:01 AM
my R1 engine came with 130 mains as standard. If you're having to fit 128s then you have a problem that ram air isn't going to fix. (especially as you have to get up some serious speed for ram air to do anything).
