R1 blowing out oil plugs
bitsilly - 4/10/08 at 05:32 PM
At both the last two track days I have been to, my R1 engine has lost the oil fill plug.
The first may have been bad luck with a loose plug but the second I tightened it by hand as tight as I could (though my mate may have over filled it with oil after the first time).
I now have an aluminium plug which I intend to lock on but was wondering if the above is a sign of bigger problems, or just a blocked breather or channel or something.
ps .
mangogrooveworkshop - 4/10/08 at 05:33 PM
possibly blocked sump vent or blow past on rings
adithorp - 4/10/08 at 06:58 PM
I can't see crank-case presure unscrewing it. Sound like it just wasn't tight enough and heat and vibration did the rest.
adrian
Tangerine Scream - 4/10/08 at 08:44 PM
Yup, lost one due to vibration (I think)
Drilled a hole and lockwired the new one to a nearby bolt and hasn't come loose since
hobbsy - 4/10/08 at 10:56 PM
Apparently this is fairly common.
I drilled a hole though the plug and got a big spring to put tension on it and stop it vibrating loose.
I would've wired locked it but CBA to keep re-doing it if topping up or changing oil.
bitsilly - 5/10/08 at 05:33 PM
That is good news!
I'll fit the new one (and fit the new prop shaft) and hope for the best Saturday at LLandow.
TimC if you are out there I should be there all day.
Cheers all.
Ed
adithorp - 6/10/08 at 10:59 AM
I've just seen this while looking for something else. Halfway down the page.
http://www.robcollingridge.com/kitcar/design/engine/index.html
adrian
TimC - 6/10/08 at 12:30 PM
Cheers all.
Ed
Hi Ed. I won't make it I'm afraid. I'm off to Mallory on Sunday to watch the racing so Saturday will have to be my MBA study day.
bitsilly - 8/10/08 at 06:01 PM
Well spotted Adrian! I'll see if that works with the Ali one.
Tim, what is more important, a career or a day at Llandow?
TimC - 9/10/08 at 08:13 AM
Watching has become VERY frustrating!
