A-arm bushes
Jonas - 18/1/12 at 12:38 PM
Hi!
Im building a Luego Velocity kit bought many years ago.
I have managed to lose one of the A-arm bushes.
I rather not buy a complete kit as I only need 1 (half), does anybody have 1 or 2 that I can buy?
RedAvon - 18/1/12 at 12:55 PM
Hi,
I have some metalistic suspension bushes I have taken out of my Tiger Avon as I'm swapping to the nylon type bush.
They have been inserted and removed but not used on the road - as the car is unfinished. If you can find out if these will fit your suspension I'll send them to you for the cost of the postage.
Ian
Jonas - 18/1/12 at 01:40 PM
Thanks, but the bushes I need are the black nylon type (as supplied by Luego).
rusty nuts - 18/1/12 at 08:13 PM
Can't help with any bushes but if you haven't already seen it do a search on here for crush tubes , It may save you loads of grief.
Jonas - 18/1/12 at 09:50 PM
Im aware of the crush tube problem (if you mean they are to tight?)
I have solved it by turning down the flanges on the bushes in a lathe.
Steve Lovelock - 30/1/12 at 10:33 PM
The best solution is to throw the hard plastic bushes away and by proper bushes along with stainless crush tubes from a respectable company. I know it is expensive but it is the best way.
MakeEverything - 30/1/12 at 11:00 PM
I have a spare pack of bushes with crush tubes, but they are blue powerflex ones. Will also need to confirm dimensions!
Jonas - 31/1/12 at 08:24 AM
Thanks Richard, might be interested if I cant find Luego ones, sent a PM.
MakeEverything - 1/2/12 at 08:28 AM
U2u replied.
