Clutch Cable
Kev1n - 16/6/19 at 06:23 AM
Hi everyone
My Velocity is eating clutch cables, like every 200 ish miles, I even have to carry a spare.
It uses QCC1260 Ford sierra with a kind of ball joint end that attaches to what looks like welded/modified bracket on my clutch pedal. the build manual refers to m6 hole using a 8.8 bolt washer and nyloc nut so the cable can pivot freely, so the cable in picture has a mounting eyelet ?
anyone got any part numbers ?
ford type 9 box 2.8 v6
thanks all
Kev
cliftyhanger - 16/6/19 at 07:10 AM
Where is the cable breaking?
That will tell you where the problem is.Basically anywhere the cable is stressed it WILL break. (I have this issue, but I get 5K before it happens)
If it is breaking every 200miles something is VERY wrong and a new cable is not the answer. I don't like the sound of the welded pedal either.
Now, pictures help, IF you can work out how to post them... or maybe links to a pic hosting site?
rusty nuts - 16/6/19 at 09:04 AM
Does the cable break at the pedal end ? Sounds like it’s not pivoting around the bolt or it’s pulling at an angle. On my car I made up a sleeve to get a decent straight pull on the cable
matt5964 - 16/6/19 at 06:23 PM
I had this on my XT and the break was at the pedal end at the join as the cable was not freely pivoting
I used a shoulder bolt and a nut each side of the attachment of the pedal with washers to ensure the cable was free but I still have a strong connection
Science I’ve done that not had one go in 2 years and 14 track days 🤠
Kev1n - 17/6/19 at 09:52 AM
Thanks everyone
yes it is on the pedal itself, it breaks right at the nipple end,
you guys are right, the bend is to severe, I think it need something like a clutch quadrant.
Ive got it booked in with MK kitcars in Braintree im sure they will sort it out.
ill post some pics up but basically I have a "c" shape welded to side of the clutch pedal and the clutch cable hooks into.
bit like a bicycle brake cable, when you press the clutch there is no pivot point so it literally tries to turn the nipple 90 degrees, hence why they snap. im sure its a quick fix. but dam hard to photo !
Thank you all.
