IVA and oil leak....
Dave Bailey - 19/7/13 at 07:52 PM
Looks like I have developed a gearbox oil leak... Only a very slight weep dripping off the bell housing.... I'm going to wipe it.... Anyone know if his will be an issue for IVA... If I get a leak?
Dave B
britishtrident - 19/7/13 at 08:24 PM
Lower the oil level a bit if it is a type 9 the level should be about a thumb width below the filler level. Ford specified a lower level because of problems leaks.
Dave Bailey - 19/7/13 at 08:36 PM
Ok thanks......
Dave B
daveb666 - 21/7/13 at 10:00 AM
Have/had a very very minor leak on my gearbox. A drip every noe and then, was never mentioned.
rdodger - 21/7/13 at 10:09 AM
IVA manual does say that there should be no leaks.
You really don't want to wee the tester off by dripping oil on his head!
Dave Bailey - 21/7/13 at 09:29 PM
I guess this is how things go..... Just before IVA a week tomorrow my screen cracked last week and I replaced it today only for it to crack again... I am going to try and work out fixing it but if ths fails going without a screen may be my only option.... Can I just take the screen off and go completely without? Cover the wiper drives etc.....
Dave B
[Edited on 21/7/13 by Dave Bailey]
Jimfin - 22/7/13 at 07:47 PM
Comment I got from the tester was "that's not much of a drip from a type 9".
For 2 screens to crack suggests some kind of stress which you need to investigate before going for a third! IMHO for the IVA, remove the whole screen fixing, wipers, washers, get yourself a pass and then, at you leisure work out what's happening and how to fix it.
