As per the title guys....
Need to get some oil for my LSD. I have heard that the quaife ATB uses 'normal' diff oil.
Any advice ?
Thanks, Mark
Ask quaife. They are usually pretty helpful
I think they take std oil too, but would you risk it on a £600 diff?
David,
Their website quotes 'SYN 75W 90' synthetic.
I wanted it today and I only have Halfords as an option really. I will go have a look...
R.T. QUAIFE ENGINEERING LIMITED
VESTRY ROAD
OTFORD
SEVENOAKS
KENT. TN14 5EL
ENGLAND
Tel 01732 741144 or 0845 130 7400 (local rate)
phone them
It is just normal diff oil as the limited slip action is provided by helical gearing etc and not special oil (like in a vLSD - v for viscous).
I just put the normal smelly stuff in.
Motul Hypoid something or other, something like this:
http://www.opieoils.co.uk/p-973-fuchs-titan-gear-syn-75w-90-semi-synthetic-driveline-oil.aspx
But just bought it from my local GSF motor factors. Its about £6 or £7 quid a litre. Supposedly you need 900ml IIRC but in the end I needed a little
bit more. You need to make your own kinda dip stick out of a bent bit of wire.
I used red line 75w90 (API GL-5) in my live axle with quaiffe atb, as said no need for lsd specific oil. Spoke to the guys at opie oils, really
helpful...
Thanks guys, I have bought this at the local Halfords so I hope to be back on the road tomorrow
Oil
