Hi,
Perhaps someone can help me.
I am looking for the distance between the pivot point of the pedal and the foot pad.
If I am right the pivot is the center of the quadrant that has a radius of 45 mm
So if you let me know the distance, I can calculate the pedal Ratio.
I am talking here about the Sierra clutch pedal with a cable system.
Best regards,
Cobra289
Approx 275mm from the quadrant center pivot to the centre of the pedal, HTH
Mike
Mike
Don't forget that if you want to adjust it later, you can just buy a different diameter quadrant. You probably know that anyway though.
