Does anyone know of anywhere in the south that can lighten/balance a flywheel. Also, any ideas on how much it might cost?
Cheers, Adam
I bought mine from scholar engines
This is for a 4age engine btw Scholar engines don't seem to do anything with them but cheers anyway.
Oh, not an electrical fault then.....
Try Roe Engineering in Fleet. tel 01252613404 - think he's open Sat am.
Cheers, Pewe
Cheers, Pewe
get the clutch and crank pulley done as well as the are all on the same axis
just balance the whole bottom end, crank and rods too"
Another yes for roe engineering in fleet as they used to do all my machining work for my race car, very helpful and relatively cheap.
Don't know your particular engine but you might like to discuss with Roe whether there are issues with taking the fly-wheel off , skimming and
remounting it in realation to crankshaft balance.
At the very least the flywheel needs to go back onto the crank in the same position (not a prob if it's pegged of course).
HTH.
Cheers, Pewe
Well the clutch has just started slipping horrifically, so it doesn't look like i'm going to have time to find another flywheel and have it
lightened before I have to fit a new clutch.
Thanks for the help anyway! Will keep Roe Engineering in mind in case
