Sierra / Granada column bearing wtd
goodguydrew - 5/3/11 at 10:53 AM
Where have you guys sourced the full bearing kit that supports the steering column at the pedal box?
Does anyone have one available?
Andrew
OK, so I have found them on eBay, but how should they be mounted? Is it inserted into a fabricated piece of flat plate?
[Edited on 5/3/11 by goodguydrew]
big_wasa - 5/3/11 at 11:03 AM
SBPFL205 SLFL STEEL OVAL BEARING 25MM BORE on eBay (end time 08-Mar-11 20:44:42 GMT)
There may be cheaper, its just the first one I found.
big_wasa - 5/3/11 at 11:08 AM
Does your column go over or through the bulkhead ? Mine is over and I just spaced it away from the plate that had the rubber bush through it.
stevegough - 5/3/11 at 12:40 PM
Simplybearings.co.uk £10.63 link
Is the one most of us used. Photo showing how I've mounted mine:
stevegough - 31/3/11 at 08:48 PM
Closer pic (posted in reply to question from 'Mads'
