sierra shortened m/c push rod
andywilson - 4/8/13 at 09:13 AM
hi all
i'm having to remove the servo as part of my z20let install as the inlet manifold will catch on it.
I remembered a while ago that tiger did a shortened push rod that did they job. having looked on their website they do still sell them, but don't offer postage.
does anyone have a dimensioned drawing of the part so I can make one?
thanks, andy
40inches - 4/8/13 at 10:27 AM
It's a while ago now, but if I remember correctly, when I removed the servo from my 2B I used a length of threaded bar, with a nylock
nut used to form the domed end.
britishtrident - 4/8/13 at 02:12 PM
If you remove the servo you will have to press very hard on the brakes to stop the car unlees you change to a master cylinder for one more suited to non-servo use ie one with a smaller bore.
jacko - 4/8/13 at 05:20 PM
Well mine is a sierra m/cylinder and i don't have to press hard on it
Jacko
britishtrident - 4/8/13 at 05:52 PM
Jacko
Contrast with experience of a lot of other builders...............
