Shock length TMXR build
dwebber597 - 25/10/16 at 02:09 PM
Hi all,
What size shocks are you all using on your TMXR builds? At that stage of my build now and I've read so much conflicting info I'm getting confused
Dave
procomp - 25/10/16 at 03:45 PM
Hi
iv'e supplied a few sets for these and no two orders have been the same so far. !
I would say get the chassis chocked up to the ride height you need with your chosen wheel tyres and then measure the distance between the damper mount hole centres front and rear. you can then determine the correct open and fitted length damper for your application.
Cheers Matt
dwebber597 - 28/10/16 at 11:14 PM
Thought that might be the case. Thanks
