Alternative hubs/uprights
hood2bx - 5/1/03 at 01:13 PM
Hi all,
This has probably been asked before, but I can't find it in the history so..
Apart from Cortina Mk 3-5, are there any Ford hubs I can use instead. Can I use Sierra ones with a suitable insert at the top (as sold by Robin Hood) or does this alter the geometry at the front end, what about RWD Escort or Mk 2 or 3 Granny bits?
Any help app' as I want to widen the search for these bits a little (someone has hidden all the Cortinas round here!)
Glenn
Duncan - 5/1/03 at 03:51 PM
Yes you can use Sierra ones. Adaptors are available that allow you to use the transit top ball.
Search through the site and you will find details of suppliers.
If you really want Cortina bits you can get complete front uprights and hubs for around £35 each from
www.auto-recycle.co.uk
interestedparty - 5/1/03 at 03:55 PM
You will need to use shorter top wishbones if you use Sierra hubs, and I'm pretty sure that Cortina lower ball joints are NFG for Sierra hubs. MK drill Sierra hubs to take maxi balljoints
John
UncleFista - 5/1/03 at 04:50 PM
Tyey're still about if you look around, check your local "Yeller" or "Freeads" etc.
If you're feeling flush, check out ebay etc.
Ebay hubs
[Edited on 5/1/03 by UncleFista]
John - 5/1/03 at 06:34 PM
Just another question on the same Sierra hub subject, if a Maxi bottom ball joint is used rather than Cortina, does the hole need to be taper drilled.
John.
interestedparty - 5/1/03 at 07:12 PM
John.
Yes
John
John - 5/1/03 at 10:41 PM
Thanks John.
I think I will carry on looking for Cortina hubs.
John.
hood2bx - 7/1/03 at 03:51 PM
Cheers all, I think I will carry on the search for Cortina ones also then...
Glenn
James - 7/1/03 at 04:38 PM
Glenn
Another annoyance with using the Sierra hubs is that you can't use standard length wishbones. The offset between the centre of the top balljoint and the bottom is different from the Cortina.
HTH,
James
Rorty - 8/1/03 at 03:04 AM
All this stuffing about with heavy, over-engineered (for a light Locost), mismatching car parts!
Surely, in the great Locost tradition, you should make your own uprights.
The advantages are numerous:
1/ Extremely light weight.
2/ Uses easily replaceable trackrod ends or Rose joints.
3/ Optimise the scrub radius for any old wheels you want to use.
4/ Use any caliper you want, including really light 4 or 6 pot bike calipers.
5/ Pick your own steering arm length to quicken/slow the steering.
6/ Easily made in your garage from cheap materials.
7/.....I'm too modest.
interestedparty - 8/1/03 at 07:49 AM
Rorty, may I on behalf of some of the rest of us, express an interest in your home-made uprights. Perhaps we could prevail upon you to tell us how you do it?
John
davimora - 8/1/03 at 08:50 AM
Hi Rorty,
i was thinking about use sierra uprights, but yours really make me ...
I hope you'll post a drawing.. SOON! i really want something like yours.
Davide
kingr - 8/1/03 at 12:08 PM
Rorty
Please enlighten us to the construction of your uprights, they look super cool. Plus the discs look bizarre, I'm guessing they're off road, trials motorbike maybe, am I correct? The only disc I've seen like that before were for trials mountain bikes so they could take a battering and most importantly, looked cool. I used to have some on my push bike, till it got stolen
Do motorbike discs/calipers work on cars? I would have thought there would be heat/strength issues with the added weight?
Kingr
fastenuff - 8/1/03 at 07:02 PM
this is another option from rorty's but doesn't look as good though
http://www.billzilla.org/newrcarhub2.jpg
Rorty - 9/1/03 at 03:14 AM
Before I go any further, I think my uprights need a short introduction. The car weighs 390kg, and frequently hits the ground from heights up to 8 or 9 feet while traveling at about 60mph, when coming off jumps.
I have used everything under the sun over the years, including Torana (Australian version of the Viva) front uprights, and I even bent one of those.
My uprights are about half the weight of those Torana ones, yet I haven't had a single problem with them.
They are made from a turned stub axle, and two lengths of 3mm RHS. One bit for the steering arm, and the other bit has a V cut in it, then bent to the correct angle and welded.
I use Rose joints in the horizontal plane to give almost unlimited travel (in reality 14"), and turn some ball extenders to increase the angular limit of the joints to 48 degrees inclusive.
The cheapest way for the Locost would be to either use the Rose joints in the vertical plane, or use two Transit rod ends.
Again, to keep it cheap, you should be able to buy Cortina/Granada (or whatever you fancy) stub axles from any trailer parts place or motor factor, then just turn a spigot on the end for welding through the upright.
Obviously that's over simplifying matters, but you get the idea. The important bit is to get the geometry right. Now I'm only too glad to help out with drawing the jig and the upright itself, but I can see this blowing out ....some may want vertical Rose joints, some horizontal, some for Escort, some for Granada etc. and that's not even going near the various caliper permutations!
To be honest, I would rule out the horizontal Rose joints, as the ball extenders are quite hard to produce by NC...read expensive.
If someone wants to start a poll, and come up with say 4 or 5 different popular models, and can supply me with the various dimensions I need, such as ball to ball (vertically and diagonally), and distance to disc face etc, then I'll do the rest for free.
If on the other hand someone wants different hubs, bike calipers (thin discs), different scrub radius for those sexy Peugeot wheels etc etc, then I'll charge them my going hourly rate, which, with the conversion rate the way it is at the moment, is pocket money to you lot!
I design all my own discs, and have them laser cut. That way, I can maximise the disc size to the available wheel well clearance, depending on what calipers I'm using. The "bizzare" shape has several functions.
1/ The discs are as light as possible.
2/ They stay cool.
3/ The outer "cauliflower" profile actually cuts any debris off the face of the pads.
I have never warped one, even when driving on the roads, when we go "bush" for a week end. If they did start to warp, they are a fraction of the cost of a regular car disc to replace.
Fastenuff, those uprights you illustrate are fine, and I suspect they are a universal upright i,e, for front/rear, drive /non-drive use. I have made some like them for a 4WD project. They are certainly strong enough, probably a little heavy, and quite a bit more difficult to jig and weld.
Metal Hippy™ - 9/1/03 at 03:21 AM
Hmmmm interesting.
Could be a potential solution as to how to use the running gear from our BMW in this thread.
You may hear from me at some point Rorty....
kingr - 9/1/03 at 10:34 AM
Rorty,
I think I would be safe in suggesting that the most popular fitment would be Sierra hubs to cortina dimension uprights. Also would it be possible to see a few pictures of your upright on its own? Finally, and less related, are your wishbones powder coated or painted? They look very nice either way.
Kingr
ijohnston99 - 9/1/03 at 10:59 AM
How about sierra ones to fit an MK Indy?
I'd be willing to send a donation!
Rorty - 10/1/03 at 03:39 AM
Kingr:
OK, I'm happy to do those, though I'll need you, or somone to provide some basic measurements. In other words, Cortina upright dimensions, and Sierra stub axle dimensions along with the relative position of the Sierra caliper bracket.
If you want to email me, I can let you have a requisition sheet with all the relevent blank dimensions for you to fill in.
I'll have to do a bit of digging, I just pulled that other image off my web site. Give me a minute, and I should be able to come up with a pic or 3D drawing.
I paint everything. Powder coating isn't tough enough, and can't be touched up.
Sure. What's the Indy based on, Cortina or Sierra? Same as above, if you contact me, I'll email you a sheet to fill in with the measurements.
All donations gratefully received.
Damn, forgot you cant attach an image by editing.
[Edited on 10/1/03 by Rorty]
Rorty - 10/1/03 at 05:03 AM
I have uploaded a few pics of one of my front upright/hub assemblies to the Photos archive. The upright is for use with Rose joints mounted horizontally. It would be virtually the same for use with say, Transit tierod ends, other than the Transit rod ends would obviously have to be mounted vertically.
I have built them with VW Beetle tierod ends in this fashion. Worked beautifully.
Rorty - 15/1/03 at 02:56 AM
how haveyou arranged the bearings in your uprights/hubs
The rod ends are orientated in the horizontal plane.
Fast Westie - 15/1/03 at 11:36 AM
Has anyone considered Metro hubs?
Before you all laugh, you get ball joints top and bottom that could be clamped, ventilated disks (small) and 4-pot calipers. Might be worth investigating.
Rorty
When I checked your photos page didn't work
Barker - 15/1/03 at 12:16 PM
I'm not laughing!!!!
I have changed to a chain driven diff which now requires metor drive shafts - the logical link is also to use metro hubs [trying to source now]. this is for the rear though.
PHULL - 17/1/03 at 07:56 AM
hey there Rorty I live in melbourne too
what side of Melb u live on?
east<-----me
I was wondering on ur opinion of Ford Falcon XF disks and calipers for this aplication?
fastenuff - 17/1/03 at 07:27 PM
I ve put in some strange brainwaves into this subject. Taking Terrapin ideas with sierra parts. The results were some odd models for fornt uprights, as seen in the photo section. height simular to the cortina part as is the angle.
Comments would be welcome
Highcost builder - 17/1/03 at 10:09 PM
Rorty, wow, respect , just one point.......
Like the idea of saving money with the diy uprights, i will consider it if the custom desinged laser cut discs are about £10-£15 each, do you think i can get them done for about that.
Rorty - 18/1/03 at 01:59 AM
Phull:
WAY too heavy M8. Go to Pick-a-part, or DatsToy in Rooks Rd, Nunawading/Vermont, and get the bits off a much lighter car. If you get the stuff of a GTi or similar, they usually have uprated brakes.
I used to live in Blackburn, but now live in Elsternwick.
Fastenuff, I think that all looks good. I've no idea what the Sierra strut/hub is like, but I presume you have utilised the hub as is, and drawn your upright to suit. My only criticism is that it would still be pretty heavy.
If you're going to the bother of using a bit of pipe for the upright, how about taking it a stage further, and turn it suit the Sierra bearings etc. too. That way, you would get rid of the casting, and two unneccesary flanges and bolts.
Highcost:
Thanks for the kind words.
I get my discs cut for about $28 each....so...divide roughly by three for pounds. Best bet would be to ask Merlin on this list, as he either has, or works for a laser cutting business. As with everything, multiples cost less per item.
fastenuff - 18/1/03 at 08:32 AM
the weight is true rorty, but this upright was made up from parts i did find as drawings.
The upright was made up from steel tube and the rearbearing of the sierra unmodified and an end piece of the driveshaft.
I don't have any parts left here sold everything, only gearbox diskbreaks and diff left, so getting dimensions is a bit hard, as in have to go down in the mudd at the scrapyard, have to get another sierra in the near future.
PHULL - 18/1/03 at 09:30 AM
thanks for the reply
well I live in Camberwell
anyway
those spherical joints u used I noticed that they are used vertical instead of horizontal...
anyway where did u go to get those spherical joints...how much Aus$ they seem pretty expensive where in melb specialises in this stuff?
six pot calipers on a bike man what bike did that come from that would be awsome,
I was wondering about the expense of getting some one to turn up some stub axels, hubs to fit bike disk brakes ect
Rorty - 19/1/03 at 02:25 AM
No, they are actually used horizontally if you look closely.
I mainly use Aurora rodends. I have an account with RBC, and IIRC, VCM10s are about $28 each, but any bearing wholesaler should have them.
Most of the big Jap road bikes run 6 pot callipers these days. Best wrecker is Vic Wreckers in Abbotsford.
Stub axles will probably cost around $80-$100 each, and hubs in 6061 will probably cost around $120 each. Those are basically one-off prices.
Macca - 22/1/03 at 04:59 PM
Has this gone any further as I want some, were do I send my money?
Rorty, do you think that bike discs/calipers would be upto the job on the road in a bec?
Cheers Col
Rorty - 23/1/03 at 02:41 AM
It's all rather died in the ar$e I'm afraid. I'm still more than happy to design a number of uprights (or whatever is wanted), free for the members here.
I need accurate dimensions of the donor components, as I'm not building a sevenesque Locost myself, so I don't have any of the uprights/hubs that you blokes are using.
I did send a requisit sheet to someone, and someone else pointed me in the direction of a pic of a Cortina upright, but it didn't have sufficient detail.
Bike callipers and suitable discs should work fine in a BEC, as it's so light. You may struggle to get large enough discs into a 13" rim though. 15"wheels would definitely do the trick.
PHULL - 23/1/03 at 06:25 AM
/me runs off to pick a part for some cortina uprights
Macca - 23/1/03 at 08:55 AM
Rorty,
I have both cortina and sierra complete hubs and will be more than happy to supply as much info as needed/requested.
I will send you a U2U with my email address if you need to ask for any details etc.
I will be running 15/16" rims due to the engine/diff combo that I have so should have room for the bike discs.
Cheers Col
Rorty - 24/1/03 at 01:08 AM
Not a problem. I will email a sheet with the dimensions I need clearly indicated. Just fill in the missing figures in milimetres, and I'll do the rest.
If anyone else has any particular requests, such as odd offsets etc, I'm prepared to give a certain amount of time to this.
Northy - 24/1/03 at 06:41 PM
I could help with photos or dimensions of the Cortina uprights and hubs.
When I was at the autosport show I saw a 'fabricated' Cortina upright. All the holes were in the same places, but was 1kg lighter I was hold. Same place had aluminium Cortins hubs, which weighed hardly anything! These were on the Randal Motorsport stand, www.randallmotorsport.co.uk the uprights were new and may not be on there, but the hubs might. Give them a ring on 01945 420777. If anyone rings them I'd be interested in prices (I forgot!).
PHULL - 27/1/03 at 07:45 AM
how would alloy hubs hold up for b4 u would need to replace them as oposed to the std items
Rorty - 28/1/03 at 02:21 AM
The AL hubs should last longer than the steel ones, as AL doesn't rust!
Seriously, as long as all the tolerances are correctly observed, there would be no difference between the two.
Graceland - 8/3/04 at 07:53 PM
quick note
sierra 2wd front hubs - buy Mk2 astra bottom ball joints fit straight in and are at the right angle for bolting to the wishbone aswell
britishtrident - 13/3/04 at 01:26 PM
Maxi balljoints are the same taper as Cortina ones --- actually better for the job as they have a neater 2 bolt flange than the angle Cortin 4 bolt fixing.
Other ball joints that have been used with Cortina uprights are Lada and Hillman Hunter..
Sierra one as mention elsewhere fit Astra MK2 balljoints --- but not all Sierras have taper fitting joints just the plain vanilla models.
