hiay people me agin i just brought i 1600xflow to replace my 1300xflow can i use the same gear box any probs it would cause thanks
They all use the same gearbox, you may need a different clutch depending on which flywheel you're using, if you remove your old 1300 flywheel and clutch they fit the 1600 no prob.
Should be fine. Only differences could be a different sump and an extra inch in the top of the block.
hiay thanks for that wish i new all what you lot know didnt even think about the exhaust i been told the clutch is still fitted so prob keep with that one thanks again terry
Originally posted by tjoh84been told the clutch is still fitted so prob keep with that one
AHH Takes me back I remember doing this when escort engines were still fitted in escorts And bike engines were only fitted in bikes Those were the days ????
I seem to remember GT 1600 eating 1300 boxes. The cheap fix was 2000e v4 replacements.
Alex
Good time to change to a type 9.
Cheers John
Depends if your gearbox came from a Mk1 or Mk2, Escort.
MK1 Escort gearboxes last about week of hard use with a 1600 engine. Mk2 gearboxes are a bit stronger but still weak when compared to any of the
Cortina & Corsair 1600/200o Capri or Sierra boxes.
Changing the box also means changing the propshaft,
1600 Xflos came with heavier flywheels than the smaller engine.
