Suspension time is nearing. Is there any standard relationship between the unthreaded and threaded section on any given bolt. I.E. will a 70mm bolt always have a Xmm unthreaded section?
I believe there is a guide somewhere on Namrick's website....I cant see it, but im sure its there somewhere!
Was this what you meant??
bolts
Doesn't specify whether there is a standard relation ship ( generally 3/4" to 1" across the range) but seems to be as close as I'm going to get.
If you buy MS airframe bolts the thread is always just long enough for I think a washer, nyloc and leaves about 2 threads showing.
Not having to cut off a load of thread and the fact that they are plated and consistent quality makes them worth the price, which isnt actually that
much.
Clarendon Eng Supplies are my normal supplier.
I think you will find the the thread length is 2.5 x the diameter on a standard metric bolt.
Thanks thats exactly what I needed to know. What a forum eh.
