Exposed gearbox?
Slimy38 - 1/2/15 at 07:27 PM
Just having a nosey at Guy Martins Volvo, and I happened to notice something peculiar about the interior;
I can't tell whether I like the idea of an exposed gearbox? I assume it's covered underneath otherwise the next thing to be seen would be the ground rushing by underneath.
I doubt I could do that with my MX5 box without some major cosmetic work!
hkp57 - 1/2/15 at 07:43 PM
Nice gimmick in a show car but not any good if you want to drive it in the real world I think
sdh2903 - 1/2/15 at 07:43 PM
I like it.
sdh2903 - 1/2/15 at 07:45 PM
Can't see an issue if you have a full floor?
hkp57 - 1/2/15 at 07:48 PM
I was thinking of the weeping oil seals, crap of the clutch etc
joneh - 1/2/15 at 08:12 PM
I guess there must be some sort of bulk head seal or all sorts of crap and fumes would come in through the engine bay.
bi22le - 1/2/15 at 08:13 PM
Unless it's justa show car
Volvorsport - 1/2/15 at 08:19 PM
clear lexan actually ...... as is the rear suspension....
currently off the road , since he stripped the cam belt and bent all the valves
blakep82 - 1/2/15 at 08:21 PM
By the flange round the tunnel tubes, I'm guessing its got some very clean polycarbonate or something covering it?
Slimy38 - 1/2/15 at 09:49 PM
Ah yes I see it now, so it is an enclosed tunnel but it's just clear. Of course I can imagine it not staying clear very long!
Smoking Frog - 1/2/15 at 09:53 PM
I like it the idea, matches the column. Although the clear panels won't look so good when scratched. Would like cool on a seven with the gearbox and prop on display, but would not like seeing the prop spinning right next to me. Think I'll pass.
threadbare wallet - 3/2/15 at 06:35 AM
Your probs find the lexans stronger than alloy sheet so dont worry about it coming in,and the anti scratch version i think its called margard is very good.
