Westfield narrow , live axle SE chassis suitable for track car or bike engine
Fitted ali panels,
Copper brake lines
Steering column, upper and lower
Trailing arms, 4no
Panard rod
Roll bar and petty strut
Escort Axle with Diff, CWP, shafts
Drum brakes
Master cylinder
Ali Floor mounted pedal box
Throttle pedal
Aeroquip hoses
Handbrake + Cable + rod
Front wishbones with drag links and bottom joints
Complete set of Black/Grey bodywork inc nose , bonnet, scuttle, tub
Will sell bodywork seperatley if required
£1595 or make an offer
Tel 079 39 266 971
[Edited on 28/5/15 by woodman]
Will sell bodywork on its own
May be interested in the diff depending on ratio if you are going to split.
I need a nose panel if you are selling the bodywork.
