Zetec bits.
emwmarine - 12/2/16 at 10:19 AM
I'm getting one of Kitspares new crate zetecs today. (hopefully)
That means there will be a few ancillaries that I wont need. Inlet manifold, injectors/fuel rail, original throttle body, exhaust manifold, clutch and flywheel.
Before I put them on ebay, would anyone on here want them?
[Edited on 12/2/16 by emwmarine]
johnemms - 13/2/16 at 09:31 AM
Hi..is there's an engine code etched on your crate motor?
linky
emwmarine - 13/2/16 at 02:52 PM
I'll go out and look.
emwmarine - 14/2/16 at 12:51 PM
Well there's a mystery. The engine stampings don't match Paul's kit car ID numbers.
There is a stamping as described on his site on the exhaust side by the bellhousing. There is also a matching set of codes on paper stuck to the cambelt cover as described.
However the numbers are G-FA - actually stamped XS7G-FA
and on the paper 2s4g 6007 FA
So no idea what that means. It is a 2.0 as it has that stamped on the other side.
johnemms - 14/2/16 at 05:08 PM
An engine number is etched on the block next to the gearbox bell housing - prefix ie; NGA or EDBA etc...
Usualy very faint - bit of wire wool and Mk1 eyeball ..
New engines have no number - but you would have thought ford would need to identify engines and have a prefix ...
(2S4G 6007 FA 2000 MAN STD EUROPE)
neilzero - 8/3/16 at 09:47 PM
U2U sent
