Two B 3.5 Tillets, carbon fibre, came out of a riot and have an attached moulded base so an easy refit in any car with a flat floor.
£300.00 each
Hi, can you let me have base dimensions please.
Craig
Hi Craig, the complete details are on the tillet site here https://www.tillett.co.uk/shop/documents/downloads/B3.5%20Dimensions%202017.pdf
But the base is 37cm.
hi
do you still have these? i've got a sylva J15 and wonder if they would fit. From the details you linked to, it looks like they need mounting at 6
points, does the base replace this? I'm in Caerphilly so not too far away!
thanks
