Winter rims
scutter - 13/12/12 at 08:09 PM
Folks I need to use the car more often so need a set of winter wheels with tyres. (took the car around the block today to clean up the discs and scared myself to death in theses temps with R888's )
I'm away until the new year, so you be looking to collect aorund then.
Does anything they can spare/wish to part with for a few months?
ATB Dan.
computid - 13/12/12 at 10:46 PM
What PCD?
scutter - 13/12/12 at 10:51 PM
Good point, Ford 4 stud. (cortina/capri) 4 * 108
Being fussy, I/m looking for 13" ideally.
Cheers Dan
Greenie - 14/12/12 at 09:16 AM
Just a quick one but how do you measure the PCD of a wheel?
loony - 14/12/12 at 09:55 AM
tonym - 14/12/12 at 09:57 AM
Easy with 4 stud wheels as it is the distance between the centres of opposite studs. With five or six studs it is the circle that passes through the centre of the studs so is double the distance from the centre of the wheel to the centre of the studs.
HTH
Greenie - 14/12/12 at 06:17 PM
Thanks for that ....
