Ford 2.0 Pinto Engine wanted
chrisridgway - 30/9/15 at 10:22 PM
Pinto 2.0 engine wanted. Will consider both standard or tuned. What do you have?
omega0684 - 1/10/15 at 05:28 PM
i have a couple of bits in the garage depends what you are after?
i have a 200 block bored to 93mm with standard crank, and std internals. but i do have a set of 93mm acrylite pistons, with rings on wide beam rods you could swop out. you would just need to find a big valve head. or you could take the big valves and the standard head i have and have the machining done to give yourself a fruity motor.
lots of spares and repairs in my treasure trove!
