3/8" UNF Bolts
Plunky - 11/1/17 at 04:35 PM
Replacing the shock absorbers and want to renew the bolts at the same time.
Looks like they are imperial as metric m10s are slightly too big.
Where can I get some bolts/nuts from? I need 100/70/60mm lengths or the nearest imperial equivalent.
Based near Portsmouth if anybody knows any local fastening shops?
Liam
gary gsx - 11/1/17 at 04:59 PM
Hi mate
I used a firm in Guildford bit out of the way but I believe they do mail order very very helpful and know there bolts they are called Margnor in Jacobs Well Guildford, Since moving down this way not really found any one else
Gary
ian locostzx9rc2 - 11/1/17 at 05:01 PM
Namrick ltd in hove are very good used them a few times
joneh - 11/1/17 at 05:07 PM
Arun Fastener in Arundel. That's where I got all mine.
https://www.yell.com/biz/arun-fastener-co-ltd-arundel-808768/
perksy - 11/1/17 at 05:57 PM
iirc mine came from Namrick
Worth checking locally though at a decent engineering supplies company or similar and making sure sure they are the right spec
nilocp - 13/1/17 at 04:46 PM
I can probably supply.
How many do you need and what length? I have nyloc nuts and washers as well.
For future reference I carry quite a range of UNF and UNC fastenings
Colin
Plunky - 13/1/17 at 04:52 PM
Hi Colin,
All sorted now, thanks anyway.
I will keep you in mind for the future!
Colin
mark chandler - 13/1/17 at 07:08 PM
Although sorted now, favourite place would be an agricultural/farming machine repair shop if you want something immediately.
