Hi Guys,
Dont suppose any one has a main bearing cap bolt with stud that is used to hold the sump windage tray on silver top zetec?
I am after just one.
Or if you know where I could source one new please let me know
Thanks,
Matt
If it’s just one for the pick up pipe look up Neil Dunne, he does them new.
The one he sells is for a black top and has the 20mm spacer built in. It won't work on a silver top.
Is yours a black or silver top ?
Ahhh have you cut the windage tray suds off then ?
Yep it’s the one thing I’ve spent some cash on this time. Gbs / kitspares was the best price on my Blacktop sump.
Your still going to have issues as the silvertop kit uses the windage tray you havnt got and all four bolts.
The blacktop kit comes with a tray that mounts to the sump but will it clear your bearing caps ?
I had a scholar sump last time. Very good. I’ve also made my own.
What happened to the Neil Dunne sump ?
Yep I am half way through a turbo conversion and I am now thinking why didn’t I just bung some bike carbs on it.
Neil Dunne sump didn’t fit, the holes in the sump didn’t quite align properly with those on the block. In all fairness it was beautifully made and
you could see a lot of thought had gone into its construction but it didn’t fit, Neil was excellent overt the phone asking me to provide various info
but to no avail so I have returned it.
It was strange as Neil advised he has made 100’s on the same JIG with no issues but something wasn’t right, he has offered to make a replacement but
if he can’t identify an issue with the one which is on its way back to him there is little point sending me a replacement.
Thinking I should just buy a ally one. My old engine has a homemade modified standard ally sump which has served me well but only holds 3.5l of oil
and with having a new engine and planning to do track days next year I really need a proper sump.
