Sierra Wiring Diagram
coozer - 29/4/06 at 12:57 PM
Hi, any one got a pdf or other format of a Sierra wiring diagram they can send me?
Hats off to you all for the bank holiday
steveridley@onetel.net
[Edited on 29/4/06 by coozer]
coozer - 29/4/06 at 03:15 PM
Its a Shappire Azure 1.6L Pinto from 1992.
I want to understand the whole wiring hareness so I can strip off the wires I don't need and use the rest on my kit.
planetester - 29/4/06 at 05:11 PM
you are better than me if you can understand the dim/dip system from the wiring diagrams.
good luck
[Edited on 29/4/06 by planetester]
RazMan - 29/4/06 at 05:40 PM
I've got a pdf I downloaded from a Russian website (I kid you not)
Coming your way soon.
coozer - 29/4/06 at 07:20 PM
Thanks chaps, got the diagrams now from you. Cheers!
I just need to trace the wires back that I need and uncderstand what the others are before I cut them out.
It helps to understand where all the bits and pieces are powered from.
Scratching your head without the diagram but easy deasy with the pictures.
02GF74 - 29/4/06 at 07:21 PM
Originally posted by CaLviNx
good luck
What dont you understand ? break it down in to little chunks to understand it.
Regards
well if it is anything like the mk2 escort, then that has me stumped; I can iunderstand the wiring but it does bot explain to me how the contacts are made when the levers are moved.
planetester - 29/4/06 at 07:51 PM
I dont really need to know anything, Ive rewired the sierra fuse box to do away with dim/dip, I have retained the use of the relays for dip & main beam & earthed them thro the column stalks
RazMan - 29/4/06 at 09:50 PM
Dim /Dip was always a daft idea anyway IMHO
