I have run out of Sikaflex and could do with some for the weekend.
Does B&Q/Halfords do anything similar
I'm sure that Car Builder Solutions will get some to you for the weekend if you call them
Mark
do you not have any automotive paint suppliers local?
i use texflex from our local paint shop. think it's about £7 a tube.
tom
I am sure I bought my tube from travis perkins - they shut at about 1 pm on sats, well my local ones do.
. B&Q/homebase don't sell it.
I think B&Q etc only stock silicone based sealants... Avoid at all costs! (rust)
Are there any boat chandlers near you? they may stock some PU adhesive. or possibly a professional decorating store?
I always use this stuff:
link
you might be able to get an express delivery?
HTH
Most of the motor factors round my town seem to sell something like TigerSeal (or whatever it's called), or a similar product from Granville.
They're both black PU sealant.
Just be prepared for a nasty shock when you see the price...
It's ALWAYS worth shopping around for this stuff, if time allows.
It's worth getting the proper stuff as you want to get something sticky but flexible. Normal bathroom sealant isn't very sticky... Strangely
Tigerflex is sold as a sealant even though it makes a brilliant flexible adhesive compared to some tubes sold as flexible adhesives!!! Hope that
cleared it up
I'd go for Sikaflex or Tigerseal. Can't remember what Sikaflex you need- they make quite a few different adhesive sealants and you want to
get the proper one....
Contact the lads at Mac1. I ordered mine on the phone one Thursday, it arrived next morning. Was Wurth Bond&Seal I think.
HTH
Mike
Evo-stik "Strong Stuff" has been recommended before and can be got from B&Q
http://www.locostbuilders.co.uk/viewthread.php?tid=42222
The description on the Bostik website makes it sound like a candidate.
http://www.bostik-findley.co.uk/
Originally posted by BenB
It's worth getting the proper stuff as you want to get something sticky but flexible. Normal bathroom sealant isn't very sticky... Strangely Tigerflex is sold as a sealant even though it makes a brilliant flexible adhesive compared to some tubes sold as flexible adhesives!!! Hope that cleared it up
I'd go for Sikaflex or Tigerseal. Can't remember what Sikaflex you need- they make quite a few different adhesive sealants and you want to get the proper one....
Here's an intersting source for you....
Pond shops! apparently it is used for sealing pond liners, and incidentaly you can also get that corrugated plastic tubing for your loom and plastic
hose joiners for your cooling system from pond shops
Paul, I may have a new tube of Tigerseal in my garage you can have if you're desperate. But have you tried Autoden?
i got some sikaflex your welcome to have if you want. It'll need to be collected from Belper if your nearby. Send me a u2u
Machine Mart sell white polyurethane sealant.
Pat...
Wow.... thanks for the replys, I never knew there were so many alternatives. Cheers for the offer Derek
I do need some other bits off CBS so probably give them a call tomorrow and get them special delivery.
The only reason I ask is that theres a B&Q next to where I work so wondered if it was a quick fix
