Managed to buy an ML7 a couple of years ago. ( Wish I had done it 10 years ago when I retired but that is another story ). I have learned to do basic turning and boring and am now about to attempt tapers, but I aspire to make some intake trumpets with bell mouth openings. How do I do this? Do I need to grind a special tool or is there a trick to use a single point tool to execute a radius in the horizontal plane? I cannot figure this out. For info I have a 4 position turret type tool holder. TIA.
If turning between centres you can offset the tailstock.
Or you can use the compound slide.
For the radius you could use a ball turning attachment .
[Edited on 27/5/14 by big_wasa]
Have a look at this series of videos - Tubelcain - I know the lathe is an Atlas but it's
very similar to yours.
Also this may be helpful
I thought trumpets spun using a bending technique (tool) while spinning the job?
Have a look for a "Ball Turning Attachment"
Trumpets are a lot better spun rather than turned. And a lot quicker.
Well, I need to look into the dark art of spinning as well, another skill I do not have. Thanks for the advice and links folks.
Well if you make a former from alloy you could then lay them up in carbon fibre.
This may help with your trumpet design :
Trumpets
