WANTED: 44mm 12 point (Bi-Hex) socket or cranked ring spanner
MK9R - 17/3/16 at 09:24 AM
Cant for the life of me find one that isnt a 6 sided impact socket!!!
Can any one help??
Pojo - 17/3/16 at 09:34 AM
How about this
FACOM K.44 3/4" DRIVE BI - HEXAGONAL ( HEX / HEXAGON ) (12 POINT) SOCKET 44MM
Very expensive though
MK9R - 17/3/16 at 09:36 AM
Lol just found that!! Annoying I have to cut it up as its too make a tool for the workshop. Can't even check itsvthe correct size without cutting it up.
And yes expensive, was hoping for some cheap poo as got to weld it on to an adaptor
[Edited on 17/3/16 by MK9R]
Pojo - 17/3/16 at 09:37 AM
good luck
Rosco86 - 17/3/16 at 09:54 AM
how about getting something laser cut instead?
nick205 - 17/3/16 at 10:04 AM
A shame you have to modify it
I've done that before and then realised I need the original tool.
theconrodkid - 17/3/16 at 11:16 AM
ill have a look in the dark corner of my garage later,does it have to be bihex?.
rj - 17/3/16 at 12:33 PM
I got a 3/4 drive socket set recently, all 12 point sockets, £40 delivered off ebay. I will no longer be defeated by hub nuts !
MK9R - 17/3/16 at 12:47 PM
Has it got a 44mm though??
tul214 - 17/3/16 at 01:03 PM
A bit cheaper
MK9R - 17/3/16 at 01:07 PM
Originally posted by tul214
A bit cheaper
Brill thanks. Ordered
theconrodkid - 17/3/16 at 02:54 PM
found it in the end tho 50mm may be a bit slack
nick205 - 17/3/16 at 03:05 PM
Now hub nuts are hard work - tight and need some muscle to loosen/tighten.
