I probably already know the answer to this question but thought I’d ask the wise, can you use a top mount regulator in a side mount cylinder? I’m
guessing you can but a flow meter would be useless?
TIA
Chris
My welding gas has the twin gauge on their side, the flow rate meter seems to work ok?
I run an acetelyne regulator on its side and it has always worked. My Argon regulator allows me to swivel the flow meter so whilst I do not need to I could turn it on its side.
Cheers for the answers, pleased to report you were correct worked fine with the gauges horizontal, managed to keep the flow meter vertical.
Ta muchly
Ta muchly
