Avast switches self off - other free recommendations?
v8kid - 23/6/10 at 07:56 AM
My free avg switches itself off after a couple days after downloading and to my mind antivirus which don't work is worse than none at all.
As a temp measure I've installed Clam.
Is it any good? Any other recommendation please?
Humbug - 23/6/10 at 08:06 AM
Sounds like a setting must be wrong, as I've used Avast for at least a couple of years with no probs.
I used to use AVG which was OK, though I think it only virus checks files on opening, not on downloading...
cd.thomson - 23/6/10 at 08:11 AM
AVG and Avast are two different things. Which are you having problems with? It sounds like you have some shareware version of AVG.
Install Avast instead.
Surrey Dave - 23/6/10 at 08:19 AM
It needs a free license code after 30 days? or it switches off , or you can just install again , doesn't take long.
I found my computer jolly slow with AVG.
mad4x4 - 23/6/10 at 09:22 AM
If you get the right version it is free for non-commercial use - you register once and it last for a year.
v8kid - 23/6/10 at 10:49 AM
Ah! did not realize they were different. It was the Avast free antivirus I downloaded. After 2 days it switched itself off and would not switch on as file was unavailable.
Reloaded it and same thing again.
Will try a 3rd time since it works for you guys I must be doing summat wrong.
designer - 23/6/10 at 11:10 AM
I have no problem with Avast, both english and french versions.
Hate AVG, slows computer down.
Dale - 23/6/10 at 01:02 PM
Avast uses a much smaller foot print than avg does.
Dale
Humbug - 23/6/10 at 04:19 PM
I know that... I've got Avast now and I used to have AVG . I prefer Avast
[Edited on 23.06.2010 by Humbug]
Staple balls - 23/6/10 at 04:29 PM
For paid AV, I really like nod32.
Free*, I've heard a lot of good about MS Security Essentials, Though I've yet to test it.
*assuming your copy of windows didn't get found on the floor.
[Edited on 23/6/10 by Staple balls]
dlatch - 23/6/10 at 04:47 PM
tried them all at some time and i always return to AVG it still does the job but on slower computers will affect performance as it has become quite a large program
avast was a good program but i have had virus problems while using it so i went back to avg
also to get round the zonealarm/avg issue use online armour firewall its bloody ace and runs well with avg
also sounds like you using avg shareware download the free version
drhunter - 23/6/10 at 06:37 PM
I started to use MS Security essentials after the latest version of AVG seemed to slow my PC down quite a bit.
