Paint prep while driving car
Jumpy Guy - 7/8/10 at 12:39 PM
Well, not actually driving at the same time....
Some of my car is prepped and etch primered. Some has build primer coats.
some is bare alli.
My question- Ive been driving the car like this. What do i have to do to prep it for the final coats?
Can i Panel wipe primed panels?
do i have to W & D all over again?
PSpirine - 7/8/10 at 12:46 PM
I would do a wet and dry all over using 600 ish... alternatively give it a quick over with 400 grit then wipe down and tack cloth, then just primer it all with one coat, then do the 600 then paint.
I would definitely want to rub it down as certain things like rubber and bug bits might not come off with a simple wipe.
Jumpy Guy - 7/8/10 at 12:49 PM
associated question -
plan was
1 Coat Etch primer
2 Coats primer
2 Coats colour
2 Coats clear
that sound right?
[Edited on 7/8/10 by Jumpy Guy]
Danozeman - 7/8/10 at 03:18 PM
I read that title and thought you wanted to prep it "while" driving it. I thought youd need very long arms!!
Jumpy Guy - 7/8/10 at 05:27 PM
I tried to make it as clear as possible!!
theres always one..........;-)
SO, will i have enough layers/coats of paint if i go with the post above?
cliftyhanger - 7/8/10 at 05:47 PM
What paint are you using? celly would need more than 2 coats of colour, I used to do 3-4 double coats, then start thinning it down (more than 50:50)
If using 2K then you should be fine. Basecoat? not sure, probably want more than 2 coats as it is solvent based....
