indicators, dipped and main beam not working
aka Keith - 24/5/15 at 11:42 AM
Had to move the scuttle around this morning whilst getting to the throttle pedal. I have now put it all together and the indicators do not work now (but hazards does), not does the dipped and main beams, (but side lights work). I expect that a wire has come loose, but just in case, is there any way to test the indicator relay or the lights relay? Or any thoughts were to start looking?
Craig
[Edited on 24/5/15 by aka Keith]
coozer - 24/5/15 at 01:04 PM
Sides and hazard will be on a permanent feed whereas the indicators, main and full are switch normally via a relay.
I'd check the live to the relay and then make sure its fully home and operational.
Having all 3 switched items off points to that area.
Good luck,
aka Keith - 24/5/15 at 01:06 PM
Cheers Steve,
I will try and have a look later today.
Craig
gaz05 - 24/5/15 at 05:57 PM
Given that the indicators (but not hazards) and high/low beam go through the left hand switch it sound as if you have just pulled the plug out of the switch. I'm assuming it's a Sierra switch
aka Keith - 25/5/15 at 10:40 AM
Thanks Gaz, simple. found a connector that had puled apart under the dash. simple plug and back they work again.
Craig
