Bike Tachometer
max2503 - 12/8/17 at 09:02 PM
Has anyone fitted a motorcycle tachometer in their project? I just like the look of some of them, and it would be something different.
I'm running a 4age with an emerald ecu.
Many thanks
Nathsx - 12/8/17 at 10:39 PM
Its been done plenty with the bike engines unsure on using it on car engine though
MikeRJ - 13/8/17 at 11:15 AM
The majority of 4 cylinder bike tachometers would only get a fraction of the range used when hooked up to a car engine.
Angel Acevedo - 14/8/17 at 06:36 PM
It will depend on your Redline and the redline of the Donor motor on the Bike.
If you donīt mind it is irrelevant as long as the donor bike tach rerads higher than your engine can rev....
Which leads to what Mike RJ is talking about.
Nathsx - 15/8/17 at 10:19 AM
https://www.carbuildersolutions.com/uk/all-in-one-digital-dash-10k- black-face
This gives a similar idea but much less RPM, Fairly costly though
