Astra G clutch replacement anyone done one?
t16turbotone - 26/1/10 at 10:26 AM
Hi peeps, clutch gone on astra van, mate of mine tells me you have to drop the whole subframe out with steering rack etc etc...anyone know of a quicker method pls? 1.6 8v model x16szr
thanx
tony
ashg - 26/1/10 at 10:55 AM
yep done 2 now. hang it on the engine crane engine mounts off push engine over seperate gb but leave it in the bay replace clutch put back together. first one i did took about 3hours the second one i did in about 2 hours.
i never understand why people insist on removing the whole gb out of the bay just to change a clutch when in reality you only need to split it just enough to get your hands in.
t16turbotone - 26/1/10 at 11:19 AM
thanx ash, will there be enough room to replace hyd slave using your method?
ashg - 26/1/10 at 12:46 PM
you might get away with it but it will be tight if you remove the drive shafts you might be able to tip it upwards to get at it.
[Edited on 26/1/10 by ashg]
