I drove 63.4 miles with a full tank then refilled my tank I put in £7.73 and it was 5.95L at £129.9 per L can anyone tell me my mpg ?
Approx 48.6mpg If my long forgotten maths still work
Is this a real question???
Change litres to gallons, so 5.95/4.54 = 1.31 gallons
Then divide distance travelled by gallons used so, 63.4/1.31 = 48.4 mpg
Davie
Yes it is a question ,as for real??
What amazes me is how you managed to get 5.95L of fuel @ £129.9/L for only £7.73 :p
Tilly
48.44 mpg
12p per mile
I used the mpg calc free app I use for my car to check when it needs a service.
I fill it n reset mileage then when I fill up put in cost n ltrs n miles n it works mpg n maps it over the tie u use it.
It's free app for iPhone
So my car did 51.6 mog after the oil change n fuel n service now it's in 48.7 n it's due a service.
It goes back up after oil, fuel filter air filter change etc.
Given I did 6700 miles in dec it is a big saving knowing when it changes.
Thats a lot of miles! I only do 6000 a year between tin top and the kit!!
48.44 mpg
12p per mile
Do you not perhaps think perhaps the colder winter weather is lot more more to do with the increased fuel consumption?
Unlike carb fuel engines on modernclosed loop fuel injected engines the condition of air-filter h as very little effect on fuel consumption,
modern fully synthetic oils don't breakdown in normal use and longlife sparking plugs last for 60,000 miles or more, in fact some
manufacturers state that plugs are expected to last the "life of the engine". .
That's too small an amount of fuel to get any kind of realistic fuel consumption figure. Just the differences in the amount of extra fuel you might squeeze in when you brim the tank would really skew this result. Brim the tank and drive until it's almost empty and brim it again and work it out from there.
