Mig Welder
LBMEFM - 1/6/17 at 02:03 PM
The time has come to buy a Mig Welder. I have a limited budget. Please vote for the one you have found most reliable. It's for car bodywork and general garage work.
I would prefer new.
[Edited on 1/6/17 by LBMEFM]
nick205 - 1/6/17 at 02:14 PM
I have a Clarke 151TE MIG with Argoshield. No complaints whatsoever, it's been easy to setup and use and welds very well indeed.
With regards to welding thin sheet metal it's worth watching some of the YouTube videos, which give some help. Without following the recommended method it's very easy to blow holes in the sheet and spend time over again making parts (or having to buy new panels).
loggyboy - 1/6/17 at 02:17 PM
Bought a well used Clarke 90en for £50 about 10-15 years ago, still going strong.
sebastiaan - 1/6/17 at 02:19 PM
I've had a (budget) Cebora for a few years and would not trade it for a lesser machine. Mostly done 1 and 2mm sheet metal work with it and find it very controllable. It's gone through about 7kg of 0,6mm wire now without any problems.
Edwardo - 1/6/17 at 03:11 PM
It's a shame you're so far away as I'll be selling a Clarke 90en very soon which has been great for the last 2 years general garage stuff.
I've just replaced it with a 151TE so would highly recommend the Clarke range.
40inches - 1/6/17 at 03:34 PM
Had one since 2001, recently fitted a Euro Torch with a 3metre lead. Just finished stainless welding an exhaust, and have welded 6mm plate with it
craigdiver - 1/6/17 at 04:00 PM
Try and get a gas MIG, never had good results with gassless (and the wire is considerably more expensive).
nick205 - 1/6/17 at 04:02 PM
Quick note!
IIRC the Clarke 151TE is supposed to have a 16 amp supply. That said I've run mine on a 13 amp supply without issue. I suspect if you had it wound up and were going at heavy work it might complain though.
theconrodkid - 1/6/17 at 05:03 PM
I have a cebora 130 (they make the strap on migs),bought it for £10 about 40 years ago and it,s still going strong, clarke seems to have a good reputation in the budget stakes and try to avoid gasless.
one mod i did to mine was to put a dinze socket on the front,replace the earth lead with a decent length of jumper lead cable and also replace the cable from transformer to dinze socket,now it can weld battleships (well up to 10 mm) without breaking sweat
Benzine - 1/6/17 at 06:05 PM
I've had a Clarke 151t for 10 years, it's okay, it does the job but it's not amazing. I wish I'd gone with a portamig or r-tech and spent a bit more.
mark chandler - 1/6/17 at 06:28 PM
My Clark 151te was not great until I replaced the earth lead with a commercial lead and it moved forward a quantum leap, I also upgrade the diodes when these fried themselves and it got even better.
19sac65 - 1/6/17 at 07:01 PM
+ 1 for cebora 130 turbo
Cracking little welder ,fan assisted so doesnt trip out 'cause of overheating
r1_pete - 1/6/17 at 07:20 PM
Wish I hadnt sold my Cebora 140, it was a great little machine.
Have an SIP / Snap On 160 now, the only advantage is it goes down to 25 amp, really useful for thin stuff.
Id have another Cebora tomorrow if one came up.
bonzoronnie - 1/6/17 at 07:46 PM
Cebora 180 for me.
Designed for sheet metal work + the extra power for thicker material.
Gutted when my Cebora died ( used & abused for years )
PCB gave up the ghost & was unable to source a new one, sold it for spares.
Replaced it with a Lincoln powertec 180.
Nowhere near as versatile as the cebora.
To my delight, my old Cebora came back on the market, had a new PCB fitted.
Snapped it up & it is once more, my pride & joy.
The lincoln is dumped in the corner of my workshop.
Oddified - 1/6/17 at 08:48 PM
I have an Clark 130te which must be 20 - 25 years old now. Does everything i've ever required of it.
I did a bit of re-wiring/switch/stud on the machine and use it for jump starting cars/tractors
Ian
ianhurley20 - 2/6/17 at 07:00 AM
I have a Mightymig machine which now works ok after replacing the liner with a wire one and getting a decent size gas bottle with regulator but I wouldn't buy another. The one I would buy if I replaced my 25 year old MIG would be http://www.weldingdirect.co.uk/cws-best-mig-160i-inverter-mig-welder-10672-p.asp . Noz-alls were at Stoneleigh this year and I was very tempted to buy one but until I have another chassis to make I'll stay put
[Edited on 2/6/17 by ianhurley20]
nobby_the_sheep - 2/6/17 at 09:19 AM
Also have a look here:
mig-welding forum
Might be some useful info/opinions.
HTH.
miskit - 2/6/17 at 06:36 PM
I bought one of these. Great machine. Yes you are going to pay more than a Clarke - but it comes with build in talent. You are also going top pay a bit more than a Chinese no-name on fleabay - but if this goes wrong it's fixed and back to you pronto.
I have an on-going review on the Mig welding forum - CWS Best Mig Review
[Edited on 2/6/17 by miskit]
LBMEFM - 3/6/17 at 07:22 PM
Thanks guys for your replies
