Pipe mitre
liam.mccaffrey - 10/6/10 at 09:40 AM
I need to generate a wraparound template for a 7.5 deg cut on an 18" OD pipe and I just can't remember how to do it?
Anyone shed any light?
MikeR - 10/6/10 at 09:45 AM
look up tube mitre on the web - some good software does it for you as long as you have a printer.
splitrivet - 10/6/10 at 09:46 AM
You can get it here Liam http://www.ozhpv.org.au/resources/shed/tubemiter.html
Bob
liam.mccaffrey - 10/6/10 at 11:26 AM
I had tried tubemitre but the problem is I am interfacing with a flat plate and not another pipe whic it won't let you do I don't think.
I have done it in CAD now though
[Edited on 10/6/10 by liam.mccaffrey]
MikeR - 10/6/10 at 11:54 AM
this is the other program,
http://cobratorch.net/ttn_dxf/
Its good cause it does gussets for you (Although seems to fail at the example liam gave).
Bob C - 10/6/10 at 12:24 PM
is that not just a big sinewave.....??
smart51 - 10/6/10 at 12:38 PM
Only if you're doing 90° joins. If your tubes join at an angle E.G. triangulation then the pattern is a little more complex.
907 - 10/6/10 at 12:41 PM
What happened to a set of trammels and a square?
I must be getting old.
Paul G
iank - 10/6/10 at 12:50 PM
I've got the equations kicking around somewhere if anyone is interested, and even implemented a new version of tube mitre in python outputting to a pdf for printing later. Should still have it but haven't run it in a while.
ETA: Just tried and there is a problem with the external pdf generation library dependencies.
It might be possible to approximate for a flat join by making giving the tube you are butting against a very large radius relative to the one you are cutting.
[Edited on 10/6/10 by iank]
liam.mccaffrey - 10/6/10 at 07:42 PM
I appreciate your efforts guys, thanks. I tried using a large rad in tube mitre but it was having trouble displaying such large pipes (18" and above)
Some of the ones we did today didn't fit on an A0 sheet.
I spent an hour on CAD today and could do any size or angle in about 10 mins now.
I am no programmer but as someone else said this would probably be a pretty simple one.
I'm going to blow my own trumpet a bit here as I'd never been shown how to do this and worked it out pretty much from scratch
