Variac
carlknight1982 - 27/1/13 at 06:46 PM
Can anyone think of a use for a variac? I've "inherited" one with some stuff I brought its brand new and rs list them at £399, before I go to he trouble of testing it I'm curious if anyone can think of a use for it
ashg - 27/1/13 at 07:26 PM
I will take it if you don't want it? How big is it?
carlknight1982 - 27/1/13 at 07:41 PM
10 amp
Will test it this week n let u knw if it's working n we can go from there as I need to recoupe some cash
theprisioner - 27/1/13 at 07:50 PM
I ued to use one at work, very useful for product testing and repair of switch mode PSU's
* Most variacs are variable transformers that can generate up to and beyond mains voltage.
* Some variacs can be followed by an isolating transformer which allows you to safely work on switch mode PSU's
Some people use them for running foreign voltages and stick a bolt thru the adjustment knob.
BenB - 27/1/13 at 08:00 PM
Useful for foam wire cutting. As long as you keep the volts too low. Otherwise the wire melts and you get electrocuted. Still if used with caution very handy.
liam.mccaffrey - 27/1/13 at 08:00 PM
isn't there a fella on youtube doing mad "experiments" with one of ??
HowardB - 27/1/13 at 09:10 PM
I have one it can be used for all sorts of things, but variable AC voltage is it's main use. Slowing motors, dimming lights, creating 110v etc,...
gazza285 - 27/1/13 at 09:26 PM
Used a lot by valve amp repair people for bringing voltages up slowly, useful for diagnostics.
Confused but excited. - 27/1/13 at 10:00 PM
£399!
I've got two in the garage that I've had for years. Hmmm I feel an ebay moment coming on.
smart51 - 27/1/13 at 10:19 PM
I used to use one for testing that new products would work at the full range of European mains voltage: 200V - 264.V
If you have old euro 220V devices, you can use a variac to drop our 240V a bit.
You could use one to adjust the temperature of a soldering iron (or anything else that gets hot) or for dimming some types of light bulb.
ashg - 27/1/13 at 10:49 PM
Bingo
I have one that is pretty old mainly use it for playing around with my amps and little projects. I'm just being greedy and fancy another one
