I know this is a car related forum, but I saw a few motorcycle threads.
Bear with me: I have a scooter (125cc), and the front shocks make a squeeking noise when they are compressed.
What could be causing this? What checks can I make - I believe I have telescopic forks (I think that is the correct terminology.).
Greg
Its a mouse i recon!!!
Could be a couple of things really. Dry seals on the forks, or the spring moving on the spring seats would be my first bets.
[Edited on 8/5/10 by Paul TigerB6]
Thanks for your reply...With regards to the spring moving, do I assume this would be a normal noise, or would the forks presumably need to be disassembled and lubed/ rebuilt?
Do the forks have rubber bushes? If so what condition are they in?
yes, they have bushes. However, the shocks have a rubber cover that can only be removed if the shocks are removed. There are dust seals, and below
there there are rubber bushes. However, one cover has a small hole, and I can see no oil there suggesting that there is no leak!
It doesn't cause a problem with the riding, it is just a little irritating!
