Megajolt Pinto Map
TrophyJem - 1/6/12 at 03:46 PM
I've just got my Megajolt installed and now need to put a map on it as a starting point.
Has anybody got a map they are happy with for the Pinto that they would care to share?
The engine is;
2.1L Pinto
FR32 cam
Large valve head
Twin 40 Dellortos with TPS
se7ensport - 1/6/12 at 04:27 PM
I used the following with great success on my old Pinto, it had a large valve heavily skimmed head with FR33 cam and bike carbs initially and then GSXR throttle bodies. I don't have an exportable format that will work with megajolt, but you can transpose the figures easy enough, usual comment applies about shared maps etc: no two engines are the same, my trigger signal could be in a different place than yours, listen out for pinking, use with caution etc...
Pinto map
Pinto map
Pinto map 3D
Pinto map 3D
shaft - 1/6/12 at 05:55 PM
I have a map i can email to you.
It was tweaked on the rolling road.
Spec:
2.0l Pinto, Blade carbs, FR32, Big valve head.
U2U me your email and i'll send it over for you.
TrophyJem - 1/6/12 at 06:11 PM
Pinto map
Pinto map
Pinto map 3D
Pinto map 3D
Thanks for that. I guess I might need to tone it down a bit from your settings.
shaft - 1/6/12 at 06:19 PM
Map sent via email.
ryanill - 5/6/12 at 08:05 AM
Hi all
Sorry to hijack this thread but any of you guys got a base map for a standard pinto on bike carbs ?
Iv recently put a mega jolt in my Indy. Now need a map to
Any help would be great
Ryan
mcerd1 - 5/6/12 at 09:16 AM
^^ any twin carb map should be a good enough starting point
here's a few I've collected:
Pinto Maps Linky
ryanill - 5/6/12 at 09:21 AM
Cheers for the link
Got something to do on the bank holiday now
Ryan
ryanill - 5/6/12 at 09:33 AM
Pinto Maps Linky
just noticed that the load values go over 100%
is the because they are for a engine with a MAP rather than a TPS ?
ryan
mcerd1 - 5/6/12 at 09:58 AM
some of them might be for a MAP version, they are ones I picked up from a few different sources
you can easy change the setting to TPS and adust them from there
