overfilled Xflow
Slater - 23/10/14 at 11:04 AM
Hi
I overfilled my 1600 xflow with oil.............. only by 10mm on the dipstick, will it be OK? or should I drain some out?
Paul Turner - 23/10/14 at 11:07 AM
Drain some out, its easy, simply remove sump plug.
You don't want the crank thrashing about in the oil, causes frothing, loss of pressure and guess what happens next.
steve m - 23/10/14 at 11:52 AM
It will leak out all on its own, as its a xflow
But you should take some out, as it will smoke heavily over about 3k
steve
Slater - 23/10/14 at 04:43 PM
Ok, thanks for the advice guys.
