Weld on sump plug boss & plug
Mr Whippy - 17/11/14 at 01:06 PM
Hi
I'm looking for a source of weld on sump plug boss, needing about 12 of them! So cost is an issue. It's not engine or gearbox related and not subject to high pressures or loads so I'm not too bothered about quality, they just need to be oil tight and around 1/2 inch bore and mild steel
Any suggestions?
Russell - 17/11/14 at 01:35 PM
Use weld in mild steel lambda bosses and blanking plugs with a copper washer?
Mr Whippy - 17/11/14 at 02:06 PM
yeah that would work, anyone know of a cheap source of those?
r1_pete - 17/11/14 at 03:05 PM
I've got two you can have for nowt, so that would reduce the total unit costs.....
Smoking Frog - 17/11/14 at 03:19 PM
Weld nut? M10 ones here if their big enough.
M5, M6, M8, M10 Square Steel Weld Nuts, Self Colour, Metric Threads, DIN928
Mr Whippy - 17/11/14 at 03:22 PM
Do you think I can I weld 304 stainless with mild steel flux wire? I have welded various stainless plates to mild steel before and only noticed a bit more sparks but the welds where just fine.
I see some from an ebay company Profusion that sells bosses for a couple of quid made from stainless and their blanking plugs are a couple of quid to.
Mr Whippy - 17/11/14 at 03:25 PM
thanks it's a good idea but M10 may be a bit small as I'm pouring in about 90 ltrs of oil, need something around hose pipe bore or I'll be there all day
Thanks for the offer r1_pete, I'll see how I get on buying the whole lot in a oner first though
jacko - 17/11/14 at 04:45 PM
12mm nut welded on and copper washer on the bolt
thats what i do on sumps
Jacko
Mr Whippy - 17/11/14 at 05:14 PM
yeah I suppose it makes sense to do that, I'll see if I can find some cheaper than the lambda bosses
cheers
907 - 17/11/14 at 06:00 PM
Go to a plumbing supplier and get 6 off 3/8" BSP sockets and cut them in half. ( = 12 )
From the same buy 12 off 3/8" BSP hex head plugs.
Thats the same thread as on gas reg outlets. ( argon oxygen etc )
Paul G
